Hey y'all,
I just ran my 1080TI to see what was wrong with it, because when I had it plugged into both monitors, it would routinely crash and make both monitors black, and the fans would be blowing at full speeds. However, it has not done that yet and I experimented with having just one monitor plugged in and playing - worked great. I have both in now, and just downloaded the appropriate drivers and all that. I looked up and saw that the temps seemed a bit high at idle - I put a little screenshot, showing the two different monitors - I was hoping to get some insight as to whether this is normal or not? I would love some help on this - I have a 1070, and if I remember right, I did not have as much of an issue with it - at least not with it crashing.
Thanks!
https://linustechtips.com/topic/1044541-evga-1080ti-help/
DDU the current driver and install the newest one (even if you're already using the newest)? Also try swapping cables and the ports used.
Desktop benching:
https://linustechtips.com/topic/1044541-evga-1080ti-help/#findComment-12393959
Could it possibly be something to do with thermal paste as well? And I'm using both display ports - I swapped those two I believe already. DDUing the current driver again.
https://linustechtips.com/topic/1044541-evga-1080ti-help/#findComment-12393967
thermal paste affects performance and temperature (so overclocking potential and cooler noise levels) but not function, a hot GPU that's thermal throttling heavily should still push output to multiple monitors as usual.
Maybe the display out VRM isn't working right? You can only fix this with an RMA
Desktop benching:
https://linustechtips.com/topic/1044541-evga-1080ti-help/#findComment-12393970
I'll have to work on the RMA process tomorrow. So for now, would you advice against using this card for gaming at all?
https://linustechtips.com/topic/1044541-evga-1080ti-help/#findComment-12394047
why not? If you killed it EVGA will handle the repair anyway. Playing games IS the intended purpose of this card.
Desktop benching:
https://linustechtips.com/topic/1044541-evga-1080ti-help/#findComment-12394053
I should note that I bought it second-hand, but I'll have a talk with them tomorrow. But I guess no harm done now to just run through it?
I just cranked up the fans to 61% and temps dropped obviously but I don't even hear the noise because I have headphones on so.
https://linustechtips.com/topic/1044541-evga-1080ti-help/#findComment-12394057
I dont think it can get worse. It might crash in games though, depending on why it couldn't have 2 displays output.
Desktop benching:
https://linustechtips.com/topic/1044541-evga-1080ti-help/#findComment-12394068
