So I want to build my first rig with decent specs. I want to be able to overclock it. I built a pc and need to know if I should stay away from certain things. If this list is good, I would most likely order everything from Newegg. Is this a trusted seller?
https://pcpartpicker.com/list/kdwrbX
https://linustechtips.com/topic/1044057-first-pc-help/
Some radical overchanges would need to be made in order to spend your money in the best way. NewEgg is quite large lol, ofc its trusted
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor  ($229.99 @ Newegg Business)
CPU Cooler: Noctua - NH-D15 SE-AM4 82.52 CFM CPU Cooler  ($89.90 @ Amazon)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($114.99 @ Amazon)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-2400 Memory  ($84.99 @ Amazon)
Storage: Samsung - 860 QVO 1 TB 2.5" Solid State Drive  ($127.99 @ Amazon)
Video Card: EVGA - GeForce RTX 2070 8 GB Black Video Card  ($479.99 @ Newegg)
Case: Cooler Master - MasterBox Pro 5 RGB ATX Mid Tower Case  ($65.98 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Platinum 650 W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($90.81 @ B&H)
Total: $1284.64
Generated by PCPartPicker 2019-03-13 16:45 EDT-0400
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1044057-first-pc-help/#findComment-12389398
Newegg is great... So is B&H. The have free shipping on almost everything, so I typically split the difference between newegg & B&H
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
https://linustechtips.com/topic/1044057-first-pc-help/#findComment-12389399
