Noctua NF-A14 PWM should work.
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1396168
the AF140 quiet edition? They work well and are pretty quiet plus they look good.
CPU: Intel i5 4670(non K) Cooler: Hyper 212 Evo Motherboard: Gigabyte GA-H87-D3H Ram: Corsair Vengeance 8Gb (2x4Gb) @1600Mhz HDD: WD Caviar Blue 1TB GPU: Gigabyte GTX 770 OC WF3 ~1293Mhz max boost clock~ PSU: Corsair RM 750 Case: Corsair 300R Windowed Edition OS: Windows 8.1
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1397382
Elmo....
Wishing leads to ambition and ambition leads to motivation and motivation leads to me building an illegal rocket ship in my backyard.
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1397404
Black Silent Pros should work. However, they're a tad bit on the pricey side.
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1397908
Where are you shopping/located?
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1398640
Denmark:)
Any specific shops you can link us?
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1398764
thx i think its gonna be thoose...
what rpm are you running them at and are you using 140mm or 120?
I personally use the 120mm version running at around quarter speed on a fan controller, and they are ridiculously quiet while still pushing an OK amount of air. But the 140mm version will likely be even quieter!
"The unexamined life is not worth living" - Apology 38a, Socrates
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1399219
think i gonna use 4 of thos in corsair 540air case:) thx mate.
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1399263
Not quiet enough? I don't understand even when I have my computer full blast with 7 fans(none of which are quiet edition) it's not loud.
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1400126
I have 4 of those in my R4 and they arent that quiet.  When you turn down the voltage to <7V they are decent.
Im curious to try out the silent wings
CPU: i7 4770k @ 4.3Ghz with NH-D14 | RAM: 16GB Corsair Vengeance 1600MHz | Motherboard: ASUS Maximus VI Hero | GPU: SLI GTX780 Windforce | SSD: Samsung 840 Pro | HDD: WD Black | PSUEVGA SuperNova 1300W | Case: Fractal Define R4 | Monitor: X-Star DP2710 1440p @ 96Hz | Mouse: DeathAdder  | Keyboard: CM Storm CherryMX Red | Headset: Kraken Pro | Headphones: HE-400
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1400153
You people are just get too worked up about it being "silent". Fuck that, I want it to run as cool as possible.
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1400172
If two fans can move the same amount of air and both provide sufficient cooling wouldnt you want the one thats quieter? lol
I run them at 12V when gaming, with a headset on its not noticeable.  At night I turn them down to 7V.
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1400192
Honestly I wouldn't care, but that's just me.
https://linustechtips.com/topic/104389-silent-case-cooling/#findComment-1400362
