Hi guys,
Not sure if this is the right place to post this but, what drivers do I need for a new PC?
The image I attached are the parts I got.
Thanks in adavance!
PC Specs:
CPU: R5 2600(OCd to 4ghz)  |  CPU cooler: Cooler Master Hyper 212 Black Edition  |  Mobo: Gigabyte B450 Aorus Pro Wifi  |  RAM: Corsair Vengeance LPX 16GB  3200mhz(White)  |  PSU: Cooler Master MWE 750w 80+gold  |  GPU: Gigabyte RTX 2060 Gaming OC 6GB  |  NVME: 970 Evo+ 250gb(OS)  |  SSD: 860 Evo 500gb(Games) , MX500 1TB(Games)  |  HDD: WD Blue 2TB 5400rpm(Mass storage device)  |  Case: NZXT H500(White)  |  Case fans: 2x140 Noctua NF-P14s redux-1500 PWM(Grey) , 1x120 Thermaltake Riing 12 series red led
Peripherals:
Headset: HyperX Cloud Core  |  Mouse: Logitech G502 Proteus Spectrum  |  Keyboard: Coolermaster MK750 CherryMX Red  |  Monitor: AOC G2590FX 25" Frameless Gaming Monitor
https://linustechtips.com/topic/1043827-first-build-tips/
9 minutes ago, David_Kwan said:
Hi guys,
All of the drivers.
But in all seriousness, most if not all of the drivers can be found on the manufacturers website. Sometimes they will include a cd in the box. Windows will also try to auto magically install the hardware drivers, but sometimes they aren't the most up to date.
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12387212
I just use drivers Windows grabs automatically, except the video card driver which I'm downloading from the GPU designer (AMD or Nvidia)
Desktop benching:
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12387224
21 minutes ago, David_Kwan said:
Hi guys,
Basic drivers are installed by windows, looking at your picture you will need only Logitech software and cooler master software for being able to extra functions of you peripherals.+ NVIDIA currrent drivers.
Also you should probably get some case fans and cpu cooler.Stock ryzen cooler is abysmal,don't get me wrong it will work,but your cpu will get hot.
My PC --- CPU: Ryzen 7 3700x @ 4.3 || MoBo: Asus strix x470-F || RAM:32GB@3400mhz  4x8GB Corsair vegeance pro RGB || Cooler: Corsair H150i Pro AIO || GPU: Sapphire Rx5700 XT nitro+ || PSU: Corsair rm750i || Case: Thermaltake TG 31 RGB || SSD: 1x hp ex900 nvme 500gb 3x crusial mm500 1tb || Corsair M65 elite & Corsair platinum K95 || 2x Acer ed323 qura 1440p@144hz + Samsung c27fg70 1080@144hz.tb
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12387229
From what I could see from the picture,
https://support.logitech.com/en_us/product/g502-proteus-spectrum-rgb-gaming-mouse/downloads#
https://www.gigabyte.com/us/Motherboard/B450-AORUS-PRO-WIFI-rev-10#support-dl
https://www.nzxt.com/products/h500-matte-white
http://www.coolermaster.com/peripheral/keyboards/masterkeys-mk750/
https://www.samsung.com/semiconductor/minisite/ssd/product/consumer/970evoplus/
https://www.gigabyte.com/us/Graphics-Card/GV-N2060GAMING-OC-6GD#support-dl-driver
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12387230
Assemble the parts before you put them in the PC to make sure it all works.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12387236
2 hours ago, CodeNova said:
All of the drivers.
Ok, guess I'll leave it up to windows then if there won't be a problem. So the rest I'd need is logitech, coolermaster, Nvidia drivers.(Forgot to include my gpu in the pic but it's a gigabyte rtx 2060 gaming oc) @XcooolYeah I wasn't thinking of overclocking the cpu at first but now I feel like ocing it.... But the shipping and tax is so high I don't think I'll get anything from Amazon now. Maybe 3 years down the line when I feel like upgrading. I'll check my local stores to see if they have anything decent.
Yeah I'll need to find some time off work to do that. I left it in the office because I want to use the data there to download everything I need. (Ryzen 2600 came with a gift code for The Division 2)
Nice parts by the way, you should post a photo when you get everything up and running.
https://linustechtips.com/main/forum/3-build-logs/
happy building
Thanks, I kept rethinking what parts to get but I'm pretty happy with what I got. I will definitely post a pic up after it's done.
PC Specs:
Peripherals:
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12387422
Ok so I got my pc together. I wanted to test if my  parts are working or not so I tested the system with cpu, ram and fans installed. I plugged in my  monitor but I don't get any signal.
The motherboard led lights up and the cpu cooler and system fans work. Should I have something pop up on my monitor with only those components installed?
Thanks in advance!
PC Specs:
Peripherals:
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12393673
Update:
Everything works fine! Now I just need to do some updates!
But does it always take so long to update....? @Xcoool @Jurrunio @CodeNova
It's been 20 minutes now and it still hasn't restarted yet..
Edited by David_Kwan
Additional update
PC Specs:
Peripherals:
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12394109
6 minutes ago, David_Kwan said:
Update:
That looks slick, you did a nice job, and I think the white case really makes it pop.
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12394124
Thanks, but does it usually take more than half an hour for it to restart?
I'm about to get off work soon and I don't like the idea of leaving it on through the night..
I'll take proper pics of it later and post it in the new builds. I actually thought it'd be more difficult to be honest, I'm just glad it posted the first time! lol
PC Specs:
Peripherals:
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12394129
Leaving it on shouldn't hurt anything, but 30min to power off is unusual.
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12394130
Yeah... do you know of any situation where it would take this long to restart?
PC Specs:
Peripherals:
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12394134
It could be updating, or it might be having trouble closing a program in the background. This isn't recommended, but holding the power button down for 15 seconds will power off the pc immediately (similar to pulling the plug).
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12394136
I think I'll just leave it overnight. Don't want to do anything to damage my new build. Hopefully it's just downloading some updates.
PC Specs:
Peripherals:
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12394145
that's a wise choice, looking forward to seeing your build on the build thread.
Thanks.
PC Specs:
Peripherals:
https://linustechtips.com/topic/1043827-first-build-tips/#findComment-12394150
