Hello :)
I'm currently in the process of buying the parts for my new computer, the specs of which I will list below:
Intel Core i5-9600K 3.70GHz Processor (Purchased)
Corsair H100x AIO Liquid Cooler
MSI Z390-A PRO ATX Motherboard
Corsair Vengeance LPX 16GB DDR4-3200 Memory
Samsung 970 Evo Plus 1TB M.2-2280 SSD
Gigabyte GeForce RTX 2060 6GB WINDFORCE OC Video Card
(Purchased)
EVGA SuperNOVA G2 550W 80+ Gold Fully Modular Power Supply
NZXT H500 ATX Black Case
Windows 10 Home Edition
I'm currently undecided on whether or not I should make certain compromises to get a nice fancy PC case to improve the aesthetics and airflow without drastically changing the total price of the build. My general line of thinking is that I could change to a semi-modular power supply, get a reputable air cooler instead of an AIO and then buy a nice case like this one (you can click on the text to go to the Amazon pages of the products I'm talking about). This might seem like a really dumb problem to have, but because I'm a first time builder I have absolutely no idea how cable management works for computers and I have all sorts of questions. Does the motherboard I have chosen support all the RGB fans on the new case and air cooler?. Does the semi-modular power supply I have chosen have the necessary cables to power everything?
Any help or general advice for approaching this issue will be much appreciated.
TL;DR
If I change:
for:
Cooler Master MasterAir MA610P Air Cooler
Cooler Master MasterWatt 650 80+ Bronze Semi Modular Power Supply
Cooler Master MasterCase H500P White Case
will my existing motherboard and new PSU support all the other components and RGB fans or will I run into any issues with compatibility?
https://linustechtips.com/topic/1043587-advice-for-a-first-time-builder/
are you able to change the motherboard out? and the cooler? if you can let me know and i can recommend better stuff in the same budget range as those two parts.
and keep the G2. thats a very good psu. i also would change the storage you are going with, but that's just me. I would do at most a 250gb evo ssd (if that for the price) and a 2 or 3tb HDD.
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
Since I have not purchased them yet, it is possible but I would just like to make it clear that I intend to buy new and from reputable brands that I've at least heard of before.
Edit: And the 1TB SSD was my choice and its basically a luxury I opted for with the build so I won't be changing that.
To answer your question: Yes it will work.
However, I don't see why you would, since your current planning is (in my opinion) better. Personally I would swap out that NZXT H500 for a Fractal Design Meshify C (I have been told recently that this is a very nice case) which should have better airflow than the H500.
I don't know much about RGB, so I can't really tell you how to hook all of that up. I know with some hardware it's possible to sync stuff but I really don't know anything about it. I'd advice starting a separate thread on that.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
ok. so, for the motherboard I would recommend the gigabyte z390 elite. https://pcpartpicker.com/product/GPdxFT/gigabyte-z390-aorus-elite-atx-lga1151-motherboard-z390-aorus-elite
for the cpu cooler: https://pcpartpicker.com/product/F3gzK8/be-quiet-dark-rock-pro-4-505-cfm-cpu-cooler-bk022 (dark rock pro 4) or this: https://pcpartpicker.com/product/PnPKHx/arctic-freezer-34-esports-duo-cpu-cooler-acfre00061a (arctic freezer 34 duo)
RIP
2 minutes ago, TH3R34P3R said:
I don't doubt that these parts are better but they are much more expensive than the previous components I chose.
You won't see a decent sped increase in that SSD over a SATA one.  I'd go 1TB M.2 SATA.
The G2 is a good PSU, and fully modular, not sure why you'd change that.    Unless you're trying to get all the same brand?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
they are, the motherboard will be better for the CPU and the air cooler is very good for the cost. it also removes chance of water leak failure.
RIP
Thank you for the suggestion but I would rather fork out the extra £100 for the NVMe drive to get those 3.5GB/s read/write speeds of the 970 Evo Plus.
I was thinking the same thing about the CPU cooler which is why I didn't hesitate to swap the AIO for an air cooler. I don't really know much about how motherboards affect CPU performance besides providing better thermals for the surrounding components but I had a closer look at the motherboard and it looks like the added features would benefit me since I was originally planning on buying a USB 3.0 expansion card to make up for the lack of USB ports on the cheaper motherboard. Again, thank you for your suggestions :)
https://uk.pcpartpicker.com/user/S7z7g7/saved/jJRZRB Here's a link to the list for anyone who is interested. Thank you all for your help!
