First, I know OTG cables are like super cheap and stuff but idc because im a cheap bastard and I also want to make one. Ok so I want to connect my PS3 controller to my Samsung Galaxy S7 Edge. This might be a stupid question but, could I theoretically just connect two male USB ends, one being Micro-USB and one being Mini-USB?
https://linustechtips.com/topic/1043435-diy-otg-cable/
Yup, it'll work. Just cut the cables at the ends you don't need and splice them together using this diagram I found from Google.
Image result for diy otg mini usb cable diagram
If you have a volt meter with a continuity tester (or a dedicated one) this will make the process a lot easier if the cables aren't colored inside.
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
https://linustechtips.com/topic/1043435-diy-otg-cable/#findComment-12383563
I think It'll be easiest if he uses the pre-soldered cables on both connectors, and splice and solder them in the middle, how would he connect the wires in that picture?
https://linustechtips.com/topic/1043435-diy-otg-cable/#findComment-12383569
1 hour ago, itchkowb said:
yes, just make sure your solder joints are good and the wires are spliced, and not touching
No, that's not right.
You have to short pin 4 and 5 of the host and connect the others to enable otg.
This video will help you
https://linustechtips.com/topic/1043435-diy-otg-cable/#findComment-12383867
