I plan on using these parts and I'm looking for an AIO that should be able to efficiently cool the i9-9900k with a conservative overclock. I don't plan on pushing this thing to the bleeding edge but I plan on doing some slight overclocking. I don't have a preference when it comes to RGB fans or pumps or anything like that either. I've done a small amount of research and I can't seem to find a clear winner on an AIO that will keep this thing frosty. Also, I am specifically looking for an AIO.
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  ($529.89 @ Amazon)
Motherboard: Gigabyte - Z390 AORUS MASTER ATX LGA1151 Motherboard  ($289.89 @ OutletPC)
https://linustechtips.com/topic/1043416-aio-cpu-cooler-suggestions-please/
EVGA CLC280, Corsair H110/115/150 variants, Cooler Master ML360R, Fractal S36
mind you the 9900k runs at 4.7GHz all core max frequency, so 5ghz oc is still a slight overclock in my book
Desktop benching:
The case you decide to use will dictate how large you can go. Rad size 280mm (good), 360mm (better), 420mm (best) providing the thickness is the same, but with same fan capacity a thicker rad will cool better.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
