B4 Error - Help me!
Solved by Semper,
ASRock has B4 listed as a USB device error.
Remove all peripherals, and determine if one of them is the cause, add them one by one until the error is reproduced, then check against a different port should you find the error.
_Darasuum_ ·
Posted in Power Supplies0 -
anothertealtiger ·
Posted in Programs, Apps and Websites2 -
Mumintroll ·
Posted in Programs, Apps and Websites4 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting2 -
Ozzi ·
Posted in Networking5 -
2
MadManMarsBar ·
Posted in Build Logs3
play_circle_filled
Latest From ShortCircuit:
