So for the last few weeks, I've been thinking about just what I should bring to the BYOC at LTX this year. I was thinking about this one morning while scrolling through Reddit, and I saw this post showing off a PC built in a briefcase by u/Garretttheman012. And that is where my inspiration came from. I messaged him, and he was happy to help me with some questions I had. I aimed to improve upon his idea with some custom watercooling and a display inside the top lid of the briefcase.
For the briefcase itself, I chose the vestil case 1814, for the nice look it had on the outside, and easily modded inside. Next, I decided to go with mostly parts I already had; i5 8600k, Asus Z370-i ITX, 2x8GB Corsair Vengeance LED White, EVGA GTX 1070 Ti FTW2, Intel 600p 512GB m.2 nvme, and Corsair SF600. No storage drives so I wouldn't have to worry about space constraints. For cooling, I picked a 120mm radiator and cpu block from EKWB, some bitspower fittings, and an xspc pump/res combo. Going with soft tubing for this one just for ease of access.
I received the case yesterday, and began by tearing out the foam in the bottom.
IMG_2319.thumb.JPG.1184414c6f109c8f02c867a19ae63ea6.JPGIMG_2321.thumb.JPG.f1235ea72b4f7a2203020f6bd12e7181.JPG
Decided to go with custom cut acrylic (black? haven't picked yet) to replace the foam in the bottom. Foam in the top stays. Salvaged a motherboard tray from my old Thermaltake Core V1 and a GPU bracket and riser from one of my Dad's old cases.
Threw an NH-L9i on until I get the watercooling parts together. Cablemod cables get here tomorrow, will start with some test fitting and maybe begin cutting out spots for a power button/usb ports and a psu plug. Will update then.
https://www.reddit.com/user/scarlet_shade/
Main PC: (custom waterloop)
Threadripper 1950X @ stock
8x8(64GB) Corsair Vengeance RGB Pro @ 3000mhz
Asus Prime X399-A
2x EVGA 980 Ti Classified w/ EK Waterblocks (SLI)
Corsair AX1200 w/ White Cablemod
512GB Samsung 850 Pro
512GB Intel 600p M.2 NVME
NZXT H700i White
'Media' PC:
i5 8600k @ 4.9GHz
Corsair H80i 120mm AIO
16GB TridentZ @ 4133mhz
Asus z370-i Strix ITX
Corsair SF600 SFX PSU
256GB SL308 SSD
500GB WD Blue SSD
Thermaltake Core V1 ITX Case
https://linustechtips.com/topic/1043123-briefcase-pc-project/
Okay so kinda lame update just in case anyone is watching this, but the parts have slowly been arriving and as of today I've now got everything together. I did change the GPU, I picked an EVGA RTX 2080 XC ULTRA with a Hydro Copper waterblock. I also decided to use some leather-ish fabric to line the interior since I took out the foam, and I think it'll look cool. Unfortunately I haven't had the time to start cutting holes in the actual case. Likely will start with the actual work on Monday.
Asus Prime X399-A
NZXT H700i White
'Media' PC:
i5 8600k @ 4.9GHz
256GB SL308 SSD
500GB WD Blue SSD
https://linustechtips.com/topic/1043123-briefcase-pc-project/#findComment-12399986
