hi. i have a stupid problem and i dont know to to fix that. I have a good pair of earbuds that i use for gaming as an audio device and microphone. coming from a laptop, it has only 1 audio jack and everything worked properly, now when i have a desktop, i dont know how to use that earbuds as mic+audio device. earbuds have 3,5 mm jack, and there are 2 audio ports at the front of the case and 3 at the back, but they are not reachable. Is there a way to fix my problem or do i have to buy usb headset? If relevant, mobo is Asus prime b450 m-k, everything is properly connected to the motherboard
https://linustechtips.com/topic/1042534-silly-audio-problem/
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
https://linustechtips.com/topic/1042534-silly-audio-problem/#findComment-12376015
