So i was streaming some pubg and i encountered a weird issue while streaming
Clip: https://www.twitch.tv/videos/392536413
Ive never seen something like that before you should be able to see it on the 0:40 mark little white lines all over my screen
i was just done with streaming a horror game called visage wich i streamed for 2 hours and i wanted to play some pubg when all of a sudden that happend
does anybody know what this could be,Also ive been streaming for a couple of weeks now not daily but when i can and this is the first time ive had this issue,
I stream using Streamlabs obs and i dont seem to be able to see the issue in the preview only when streaming
I also made a recording with streamlabs obs and i dindt seem to have an issue there its only when streaming
Dont know if my specs are neccesary but ill post them anyway.
Gaming Pc:Nvidia gtx 1080ti                   Streaming pc:Nvidia gtx1050 ti
                   I7 7700k                                                      I7 8700K
                   16 gb ram                                                    8gb ram
                    Win 10                                                        Win 10
Using Elgato hd60s
English isnt my first language im sorry if i offended you with my explanation
https://linustechtips.com/topic/1042341-weird-issue-when-streaming/
Link doesn't work. Post screenshot or YT clip instead. Without seeing, I would check GPU first. Temps under load and remove OC if you have any. If this continues, try different driver versions.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
