Hi soon will buy new pc and monitor.
Monitor will be 144MHz 1080p freesync .
Monitor barnd: AOC Gaming G2590FX (Free sync)
Video card: Gigabyte GeForce RTX 2060 Gaming OC Pro 6GB
This monitors is g sync compatible and wanted know what cable use:
Display port: 1.1(much cheaper) or Display port 1.2?
And this monitor is good for gaming?
https://linustechtips.com/topic/1041852-display-port-help/
the input is 1.2 so use DP 1.2.
well if it low response time and high refresh rate then yes its good for gaming
AOC G2590FX
HDMI 1.4 (x2), DisplayPort1.2, VGA, 3.5mm audio, USB 3.0 (x4)
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
https://linustechtips.com/topic/1041852-display-port-help/#findComment-12370520
You don't need any special DisplayPort cable, any will work.
https://linustechtips.com/main/topic/729232-guide-to-display-cables-adapters-v2/?output=DP
https://linustechtips.com/topic/1041852-display-port-help/#findComment-12370530
AOC G2590FX
I cant use 1.1? Wanted know if monitor have some problem ghosting, dead pixels or others
https://linustechtips.com/topic/1041852-display-port-help/#findComment-12370538
There is no DP 1.1, 1.2 cable, they are all the same. The difference is in the port and the electronic parts on the input and output devices.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1041852-display-port-help/#findComment-12370550
Why they call DP cable 1.1, 1.2, 1.3? Like i ask can i use 1.1 cable? Monitor have 1.2 and video card support all? For 1080p and 144Mhz, 1ms G-sync compatible
https://linustechtips.com/topic/1041852-display-port-help/#findComment-12370559
Some DisplayPort cables may fail at higher speeds. This is only due to manufacturing tolerances. All DisplayPort cables are designed and wired the same way and will support the same features, the only difference is in manufacturing tolerances. If you need higher speeds (such as 1440p 144 Hz) there are certifications available to ensure that a cable will handle that speed (HBR2, HBR3). If you don't need higher speeds, then any DP cable will work just as well as any other. DisplayPort cables are rated by the speed they can support (HBR, HBR2, HBR3). Using "version numbers" for cables is improper, but is commonly used by retailers because people will buy them.
All DP cables are compatible with all DP devices.
https://linustechtips.com/topic/1041852-display-port-help/#findComment-12370578
2 minutes ago, Glenwing said:
Some DisplayPort cables may fail at higher speeds. This is only due to manufacturing tolerances. All DisplayPort cables are designed and wired the same way and will support the same features, the only difference is in manufacturing tolerances. If you need higher speeds (such as 1440p 144 Hz) there are certifications available to ensure that a cable will handle that speed (HBR2, HBR3). Using "version numbers" for cables is improper.
Ok now i  understand
https://linustechtips.com/topic/1041852-display-port-help/#findComment-12370590
