overclock help
Go to solution Solved by BigDamn,
7 hours ago, Newbie390 said:
prime95 blend test has been running for 15minutes now and thats what i get
edit: i believe prime95 started a heavier test and my package, cpu core 2 and tmpin3 temps spiked up to 85 for 30 secs then they went down to under 70
Temps look fine my man. Congrats!
Hi guys my current setup is
CPU 8600k
FAN hyper 212 led
GPU 1060 6gb
PSU corsair cx550
MOBO msi z370 a pro
im already overclocking at 4.8 at 1.350 at safe temps(70-75 while gaming)
but i was wondering if this mobo can hold this overclock, i have this feeling that maybe the mobo is a bit too cheap / poor quality and i want this pc to last a few years at least.
thanks in advance.
https://linustechtips.com/topic/1041174-overclock-help/
Watch your motherboard temps in HWMonitor (or whatever you use). Remember that your motherboards VRM temperatures can achieve higher safe temperatures than the semiconductors on your CPU. That motherboard is a little cheap and doesn't have great VRM cooling. Post a screenshot of your temps while gaming and we'll see hot it looks. Worst case scenario is you knock down the OC a little bit.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1041174-overclock-help/#findComment-12364182
instead of gaming can i test it with prime95 blend test?
also in HWMonitor where can i see my vrm temps? is it TMPIN5, TMPIN 3 or CPUTIN?
https://linustechtips.com/topic/1041174-overclock-help/#findComment-12364268
I often stress test with Blender and the Car Demo on their website. Tough to say which of those are what exactly. Send a screenshot of your temps while under load. Generally VRM temps stand out above the rest.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
https://linustechtips.com/topic/1041174-overclock-help/#findComment-12364284
https://linustechtips.com/topic/1041174-overclock-help/#findComment-12364291
PC #1
PC #2
Corsair H80iGT AIO
Laptop
https://linustechtips.com/topic/1041174-overclock-help/#findComment-12365296
35 minutes ago, Newbie390 said:
just one thing, what is the max safe temp for my VRMs?
There isn't really a set temperature, but even 90c isn't something to freak out about. I wouldn't shoot for that though..
PC #1
PC #2
Corsair H80iGT AIO
Laptop
https://linustechtips.com/topic/1041174-overclock-help/#findComment-12368641
