20 minutes ago, CaptainCrawfsh said:
so i should get the 2? cause it adds up to the same amount
4 minutes ago, TheDutchRGBguy said:
Yes
No
For 4 extra FPS is not worth it, plus getting only the 8GB still will allow him to have better upgrade options, like adding a second 8GB stick
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/1040675-help/#findComment-12359609
