Just now, Bearmann said:
Do you mean that crack of light above the circular power button in your photo? Mine looks exactly the same.
Yes! Okay, thanks. I just wanted to make sure because I dismantled part of the case and wanted to make sure I had reassembled it right.
I've not had to take my front panel apart and there is NO extraneous light showing as in your photo.  I even turned off all the lights to make sure.  The seam should be flush.  If it bothers you, contact Fractal as they have very good service.
Workstation PC Specs: CPU - i7 8700K; MoBo - ASUS TUF Z390; RAM - 32GB Crucial; GPU - Gigabyte RTX 1660 Super; PSU - SeaSonic Focus GX 650; Storage - 500GB Samsung EVO, 3x2TB WD HDD;  Case - Fractal Designs R6; OS - Win10
Interesting, the other commenter says he sees it too. It only appears from very specific angles for me. That's odd.
