I have two 980 Ti's with a i7 7700k, which i believe would pull too many watts since it is OC'd. I have a dilemma, one 980 Ti uses two 6+2-pin power cords which comes from my 650 watt PSU (Modular). The second GPU uses one 6-pin and one 8-pin power cord, I have a secondary PSU which is 500 watts (Non modular) that has only two 6-pin power cords. So, the question is, can i use the 6-pin from the 500 watt on the second GPU,  and an 8-pin power cord from the 650 watt? (The 650 watt has three 6+2-pin power cords). I will probably buy an "Add2psu" adapter for the second PSU. I'm sorry for the confusing post I just need help because i can't afford another PSU and don't want to fry anything.
https://linustechtips.com/topic/1039808-using-dual-psus-please-help/
Power is power, it wont care where its coming from, as long as its getting the proper power. So yes, in theory, your plan should work.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
What are the make and model of these power supplies?
Is that in total or just on one PCIe power cable? I use a dual 6 pin to 8 pin if this happens to me.
Primary PC:
PSU tier list
How many watts do I need?
650 Watt - three 6+2- pin power cords
500 watt - two 6-pin power cords
My first GPU will be powered by the two 6+2- pin power cords from the 650 watt
And i'm trying to power my second one up using one 6-pin power cord from the 500 watt PSU and the third 6+2-pin power cord from the 650 Watt PSU, so the second GPU will have a cord from both PSU's I wanted to know if it was safe. I do have an dual 6-pin to 8-pin power adapter, but then ill have to use a 6+2- pin power cord from the 650 watt. So, either way I have to use a cord from each PSU :( Skiiwee29 said it should work. What do you think?
1 minute ago, Mat in the hat said:
Also, do I need a "Add2PSU" for them to power up..or is it just the safest way?
Yeah, otherwise you have to find some way to trip the second PSU to turn on. The adapter is way easier to deal with
I did something similar with my brother's 780 lol, it works and it was a little funny too because I was running both our systems off our PSUs combined. The 6+2 pins from the 650 watt PSU and the 6 pin from the 500 watt will combine effectively. As long as both power supplies are switched on so all the power is delivered, you're good.
(and don't forget, use @skiwee29, although mine won't turn orange for some reason)
Primary PC:
PSU tier list
Austin Evans did something very similar to this in that one season of Scrapyard Wars he was in.
Just now, Mat in the hat said:
THANK YOU SO MUCH, I've never had an account :') I've only lurked! You people are super helpful and informational!.
Glad we could be of help, and welcome to the forums! :D
1 minute ago, LukeSavenije said:
@Crunchy Dragon iirc linus did say in a different video (at freegeek) that he should have used some kind of a cable to link both
Most likely.
7 minutes ago, Mat in the hat said:
I'm not sure about that one.
Ideally you might want something more like this: https://www.amazon.com/Optimal-Shop-Second-Motherboard-Adapter/dp/B07543LNRH
Don't do this. If you don't have a good enough PSU to do SLI, just don't do it. It's just as simple as that. I'm pretty sure @TheRandomness fried a GPU doing this, and he knows what he is doing.
What are your PSUs?
Where are you from?
What stores do you buy stuff from?
Did you do it just as I described, or how did you do yours?
I highly doubt any frying would happen, but more specifically, my own system setup was different, as it was one PSU sharing power with another and two systems were running off two PSUs.
Primary PC:
PSU tier list
@fasauceome should i use the 500 watt to power the mother board and the 650 to power the two gpus? i just don't know what to do then :(
I like @Crunchy Dragon's idea with the dual 24 pin, but if you're iffy on the process my real recommendation is to only use a power supply that has the appropriate connectors for the job, as a rule of thumb.
Primary PC:
PSU tier list
