Laptop -> Display using DP
Solved by Zagna,
Disable the audio devices? There should be AMD/Nvidia High Definition Audio devices in the output section of Sounds settings and just disable all but the ones you need?
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
16
1
