Execute system command from Kotlin code?
Go to solution Solved by wasab,
Kotlin can run on Java virtual machine so it can run all the standard Java libraries so just use the Java runtime.
Runtime.getRuntime().exec("...")
If you are programming on Android, "su" is an useful command if your phone is rooted. Your app can do crazy thing with the system.... Just some tips ?
Sudo make me a sandwich
  Reveal hidden contents
Thanks! :)
I am interested in Android Programming! Please tell me more about it and how can I use it? How can I use "su" in my Android app? Please give some examples.
Thanks
Thanks
Well, I can't and won't teach you. I don't have that much free time in my life but you can learn Android programming  from watching YouTube.
And Unix shell command also from youtube. Android runs on Linux kernel so unix bash commands can be run on it as well. Don't expect all the command line ulities of Linux to be on there though. Use adb to run shell commands or download a terminal emulator from the playstore.
And read Google developer documentation for more information on Android development.
https://developer.android.com
Thanks!
I just wanna know how to use "su",
Like this?:
Runtime.getRuntime().exec("su mkdir Games")
Runtime.getRuntime().exec("su rm -rf Games")
Like this?:
 Runtime.getRuntime().exec("su")
https://en.m.wikipedia.org/wiki/Su_(Unix)
BTW I am learning Java, Python and Kotlin on Mimo: Learn to Code app, SoloLearn, Programming Hub and Udemy.
6 minutes ago, LiquidFox said:
Is this work like "sudo su" on Linux??
Sudo is not preinstalled on Android. Actually, su isn't  preinstalled on most commercial Android phones either. If you device isn't rooted and you run this command in your terminal emulator, it will tell you no su binary found.
What will happen if I run it on a rooted phone?
Does the superuser manager like SuperSu or Magisk prompt appear saying that this app is requesting superuser permission?
How to convert these python programs shown in the video tutorials down below to Java or Kotlin programs??
TL;DR
Python's Socket module alternative for Java or Kotlin.
Part One:
Part Two:
