So I'm going to build a budget gaming pc, my max budget is $600 (or euros, whatever). But I'm new to pc building and don't know which parts fit and work together.
CPU: amd ryzen 5 2600 or 1600, which one is better for only gaming?
Motherboard: MSI A320m grenade, is this good for not overclocking or should I take a newer chipset.
GPU: "XFX GTS XXX Edition RX 580 4GB OC+ 1386Mhz DDR5"
RAM: Corsair vengeance 2x4 2666 MHz
SSD: Crucial MX500 250Gb
HDD: Seagate Barracuda ST1000DM010 1Tb
PSU: corsair CX550
CASE: Rosewill fbm-x1
Does this work of am I just being dumb?
https://linustechtips.com/topic/1038760-help-with-build/
The motherboard should have a higher priority, at least B450 chipset with fine voltage regulation (VRM-s). For example an MSI B450 Tomahawk.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1038760-help-with-build/#findComment-12343206
Oh, sorry, my bad, the B450 Tomahawk does not fit into the case since it accepts only m-ATX and ITX sized motherboards. Maybe the MSI B450M Bazooka?
https://linustechtips.com/topic/1038760-help-with-build/#findComment-12343238
@harmyI would recommend this over the one you chose, and for 15 over the $600 mark, it gets you 2x the ram (faster too), an x370 board, as it would match the 1600 (which is cheaper), a 8gb rx580 instead of a 4, a 3tb hard drive instead of a 1tb. and a different pst.
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
https://linustechtips.com/topic/1038760-help-with-build/#findComment-12343366
1 minute ago, harmy said:
@TH3R34P3R do you know alternative RAM and GPU, because they are not avalible in the Netherlands.
netherlands? i will check.
RIP
https://linustechtips.com/topic/1038760-help-with-build/#findComment-12343725
so. i looked on pcpartpicker, and I see no rx 570 or 580 for a reasonable cost... and the only ram i can see with the same specs - corsair vengange lpx for 60 more than the US one.
RIP
https://linustechtips.com/topic/1038760-help-with-build/#findComment-12343736
