I'm having some problem with my 2-tier PKI setup on windows. I've got 2 Root CAs RSA and ECC. I issue certs to my servers and PCs. I'm using Windows server 2012 R2.
For example. My Exchange 2013 has problems when I test it with SSL LABS.
The results: https://www.ssllabs.com/ssltest/analyze.html?d=mail.learntotechsolutions.com&hideResults=on
Shows the chain is incomplete.
I also did a test on High-Tech Bridge and the chain shows normally:
https://www.htbridge.com/ssl/?id=3rzAtILG
I've tested the chain using certutil and it works. the CRL and OCSP works fine.
I don't what the problem is..
https://linustechtips.com/topic/1038753-ssl-chain-issues/
Currently reinstalling the CA Server. Seems to be a problem with the server itself
https://linustechtips.com/topic/1038753-ssl-chain-issues/#findComment-12343158
