Hello, i bought new PC like 3 months ago and i started couple of days ago getting this strange beeing like sound from PC, althought it doesnt sound like beeping, it just sounds like it. Watch the whole video with max volume with headphones so you can hear it more clearly.
at 0:08 you can hear it very well!
I checked GPU, CPU, front and exhaust fans and none of them made that noise. I checked around PSU and im not 100% sure if it comes from there but it kinda seems like it. Any ideas?
PC Specs:
i7 3770
GTX 1060 6gb
8GB ram
120SSD
500HD
Gigatech 550W PSU
https://linustechtips.com/topic/1038237-weird-pc-sound/
Not sure, but I think it's coil whine. Check some videos with coil whine sound, and check if it's the same with what you're hearing.
Chasis: Lian Li O11 Dynamic Evo || PSU: Seasonic PX 650 || Mobo: MSI Z690 Pro A || CPU: Intel i5 12600K || CPU Cooler: Lian Li Galahad AIO 240 || RAM: G.Skill Ripjaws V 32GB @3200 || GPU: AORUS 4070 ti Elite || Boot Drive: Samsung 850 EVO 250GB || Secondary Drive: Crucial MX300 525GB || HDD: WD Caviar Blue 1TB || Intake Fans: 3x Lian Li UniFan SL120 || Exhaust Fans: 2x Lian Li UniFan SL120 || Mouse: Logitech G Pro Wireless || Keyboard: Das Keyboard 4Q with Cherry MX Browns || Monitor: Acer Predator IPS 165Hz GSync
https://linustechtips.com/topic/1038237-weird-pc-sound/#findComment-12339212
I turned the volume at max, but couldn't hear the beeping. Try fidning some videos with the same sound (like weird PSU beeping sound or smth), maybe you can find what it's called, and move on from there. But make sure what the source is.
Also quote or tag the person/people you're replying to, so we can know you replied.
https://linustechtips.com/topic/1038237-weird-pc-sound/#findComment-12339379
Best i can describe is as like louder fan noise under higher noise. It sounds like a fan hitting something but none of the fan's were hitting anything. Ignore squealing sound in background if you hear it thats not the problem i have. Sound is more obvious around rear fan and usb ports next to it and its like a vacuum.
https://linustechtips.com/topic/1038237-weird-pc-sound/#findComment-12339586
