Hi guys.
I just switched to the Win 10 Education after getting my new SSD.
I have three audio devices in and as you can see here: http://prntscr.com/mq4b0g it show only the default one.
On my previous OS, Win 10 Pro, I coulda just click there and switch to another, but now I had to right click on the speaker, to open volume mixer, to disable the one so the other will be default and so on.
What am I missing?
Thanks.
https://linustechtips.com/topic/1038098-switching-between-audio-outputs/
2 minutes ago, seoz said:
Check in your audio devices and see if there are any disabled.
All three are enabled: http://prntscr.com/mq4d16 thats not a problem.
The problem is that I cannot easy switch them.
On win 10 pro, I had other devices here: https://prnt.sc/mq4dlx and I could just press and switch them.
Now I need to make 4 more steps to do the same.
How does your Win10 basic audio panel look like?
This is mine. Clicking highlighted arrow gives option to choose between audio devices that are active/enabled. Same arrow is shown in quick menu. And this is Win10 Home.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Man, this is totally different.
If I remember correctly, I got the same panel as you on win 10 pro, but this Edu is, I dont know.
Guys, Im so sorry.
Im retarded. Everything is back to normal after stupid Windows update.
Sorry for bothering.
Guys, Im so sorry.
Don't worry about it. I was starting to wonder what is wrong with your audio drivers or something.
