Ubuntu Problem
Go to solution Solved by Dujith,
7 minutes ago, frozeNNN said:
I'm pretty much new to Ubuntu so I don't know how to try that/what that even is. :D
Okay, lets start with opening the command line at the login screen. Before you login press CTRL+ALT+F1, that should bring you to the console screen.
From there login with your credentials. If that works you can try to do this:
sudo apt-get install xserver-xorg-input-all
Reboot and it should work hopefully.
Hello everyone,
I have installed Ubuntu 18.04 LTS like yesterday, but today it doesn't work very well. Basically, after I put my user password and it comes to desktop screen, keyboard and touchpad/mouse don't work.
Tried some commands that I found online for fixing in recovery mode but nothing worked...
https://linustechtips.com/topic/1037954-ubuntu-problem/
https://linustechtips.com/topic/1037954-ubuntu-problem/#findComment-12337079
Do you know how to find out the IP Address used by your laptop? If yes proceed to the next step: do you have an android device or another pc you can use?
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/1037954-ubuntu-problem/#findComment-12337080
24 minutes ago, frozeNNN said:
Hello everyone,
I think it freezes, could be everything
Is the HDD fine? The kernel logs would be useful, the /var/log/kern.log
What are the specs of that laptop?
https://linustechtips.com/topic/1037954-ubuntu-problem/#findComment-12337086
Okay this worked. I have tried that already but it seems like it didn't finish successfully because I didn't connect my ethernet cable (thought wifi would work), but with ethernet it actually finished it and now it works, thanks!
https://linustechtips.com/topic/1037954-ubuntu-problem/#findComment-12337116
Yeah, without internet access that wont work :D Have fun tinkering with Ubuntu.
https://linustechtips.com/topic/1037954-ubuntu-problem/#findComment-12337129
