i know this is kinda in the wrong section, but my geforce expeirence wont optimize my games it always says "unable to retrieve setting, try again later" ive done everything ppl have said to do except unistall and reinstall it Geforce expeirence. which i am about to try, but will doing that unistall my graphic driver aswell? or will the driver just run on its own and be completely fine.
https://linustechtips.com/topic/1037557-gpu-driver-help/
It will not mess with your drivers.  Just install the stand alone version of GeForce Experience, but before you do uninstall current one.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1037557-gpu-driver-help/#findComment-12333524
well it didnt change a thing, its still not working but thanks for helping so quickly
https://linustechtips.com/topic/1037557-gpu-driver-help/#findComment-12333544
If that is the case then I highly recommend you go to safe mode and run DDU "Display Driver Uninstaller" and clean and restart, then back into normal mode now install the latest WHQL with GFE along with it and let us know.
https://linustechtips.com/topic/1037557-gpu-driver-help/#findComment-12333556
Just now, Saksham said:
what games wont optimize?
I believe all of them.  It gives him a error.  Perhaps DDU can solve this.
https://linustechtips.com/topic/1037557-gpu-driver-help/#findComment-12333564
im not comfortable doing safe mode and uninstalling drivers and what not, i dont need it, it was just a quality of life thing
https://linustechtips.com/topic/1037557-gpu-driver-help/#findComment-12333586
In that case uninstall GFE then grab the latest stand alone from nvidia like I said before.  GFE does have bugs I know that much.
https://linustechtips.com/topic/1037557-gpu-driver-help/#findComment-12333592
3 minutes ago, HunterL said:
i did, didnt fix
That is really odd.  Do you remember a time when it was working for you ?  Im trying to see what happened from the time GFE was working to the time it stopped working.  You must have done something, like a driver update or possibly something else.  As I said GFE is buggy so it may not be playing nice with your OS and setup and what not.
https://linustechtips.com/topic/1037557-gpu-driver-help/#findComment-12333613
tbh i dont remember it ever working, i built this pc like last year
https://linustechtips.com/topic/1037557-gpu-driver-help/#findComment-12333643
