Hey guys, i just bought myself a new system, an R7 2700, 32gb ram(4*8gb) HyperX DDR4 2400, an RTX 2070, 650 watts 80+bronze, and PRIME B450-PLUS as the motherboard, everything is working, i am even using it to write this help topic, the problem is as soon as i put 3 or more sticks of memory ram the system does not post and gives me 3 beeps
The BIOS is the latest one, all the memory sticks are new and working, i turned the Memory OC thingy from Auto to manual and i used the Asus`s recommended setting 15-15-15-35 1.2 volts 2400
I tried googling and didnt find anything helpful if you guys could kindly help me out i would thankfuls, thanks for your time reading this.
https://linustechtips.com/topic/1037280-prime-b450-plus-memory-problem/
5 minutes ago, MarioGK said:
the problem is as soon as i put 3 sticks of memory ram the system does not post
What happens if you put all 4 sticks in?
