Uneven CPU Temps ?
Guest Generallee
Hi guys,
I was just wondering about my temperatures, I have a Core i5 3.2Ghz OC'ed to 3.8Ghz, Very stable OC no BSOD or such things.
Using Real Temp, Core Temp & HWmonitor i see that the 2 first cores at idle are at 24°C, the 3rd core is at 16°C and the 4th core is at 34°C
I don't know if it's normal to have such gaps between core temperatures, i think i didn't apply the thermal paste well  :unsure:
Is it normal ?
Also on full load, temps have the same gap, the maximum for the 4th core is 41°C under 100% load, I use a Cooler Master Seidon 120v Water Cooling Kit
It's fairly normal to have varying temps under idle and load, but not by that much at idle.
Most of the time having one core that runs hot indicates a bad mount on the cooler, Try taking it off, redoing your thermal paste and remounting it :)
I dont get how i have hyperthreading and it shows temps of the third and fourth core, then again i dont understand a lot about hyperthreading.
Listen if you care.
Do this, then we can move on to something else - if need be.
Check out the build: Used to be Obot, now Lilith
Shameless: Me
Hyperthreading is 2 front ends of the CPU feeding one physical core, so it could be possible that the temp probes are in the seperate front ends? It's something I've always wondered about too when doing i7 rigs :)
I have the same issue, where my 1st, 2nd and 4th core all have amazing thermals but get held back by the third core which is 5-7 degrees hotter. My chip is still very good but it could be top 0.5% if not for that third core. (And it's not the cooler mount, have had it in and out so many times now that I've eliminated that possibility.)
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
Yes i know that but i thought that i must have been wrong due to the temps being different. Eg right now core 0,1 are both at 39oc and 2,3 are at 35oc.
Listen if you care.
I'm pretty sure core 0,1/2,3/4,5 and then 6,7 are each module, so it could also be possible that each core shows 2 temps because hyperthreading appears to the OS as 2 cores, because they are the same core the OS see's 2 cores running at the same temp?
core 0,1 are physical and 2,3 are logical they dont always have the same temp, in idle they are grouped to together a lot
Listen if you care.
That's weird, I've never noticed that before.
But I do use Aida for my temp testing and that only shows the 4 cores :/
I use all cpu meter, ive used it since 2010 i like all the shit that it tells you, it tells you everything and you can set the refresh rate to like 0.01seconds if you wanted it.
Listen if you care.
Thanks for the replies guys, i'll unmount my cooler and re-apply the thermal paste more uniformly
EDIT : When i open HWmonitor, the +12v rail is at 8.272v Min Max & Avg Is it normal ? Shouldn't that be varying around 12v ?
