3 pin to 4 pin rgb header
Waffu1
Hello everyone I need some help trying to find an 3 pin to 4 pin rgb header adapter. I want to get the Phanteks - Eclipse P350X (Black) ATX Mid Tower Case however it requires a 3 pin rgb header. The motherbaord I have in mind has only a 4 pin rgb header. Do 3 pin to 4 pin rgb header adapters exist because I'm having trouble finding one. Also, are there any cheap ATX mobos with 3 pin rgb headers?
Welcome to the Forums!
You can't adapt 4 pin analog RGB to 3 pin Addressable as they use a completely different control protocol. What you will need is a dedicated lighting system if you want to use 3 pin addressable LEDs. Some options are the Corsair Lighting Node pro and the NZXT Hue +.
