It will technically work, but it's a terrible combo. What motherboard did you pair with the 9600k?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1037083-will-it-work/#findComment-12329733
47 minutes ago, MrStyx said:
Hello! right now I have an i5 4440 3.1 GHz processor, I recently bought an i5 9600K 3.7 GHz, But I forgot to buy a cooler with it, my question is, will the cooler I have to my i5 4440 work on the new i5 9600k processor or do I have to buy a new one?
Your stock cooler?
Like stated above, horrible idea. It would work, but not a good idea
-Llama
Ryzen 7 1700X - Cryorig C7 - Gigabyte Gaming B450 Wifi - 16GB GSKILL Aegis DDR4-3000mghz - WD Black NVMe 250GB M.2 / WD Black 2.5 1TB HD - Gigabyte Radeon RX 580 8GB - FD Node 202
"Never trust a computer you can’t throw out a window."
— Steve Wozniak
PCPartPicker - Steam - GitHub
https://linustechtips.com/topic/1037083-will-it-work/#findComment-12329786
It will work, and since its i5, you shouldn't experience massive heating. You can disable any auto-OC features, like Asus MCE to further help. But if you have overclocking in mind, I recommend investing to midrange cooler. Or to budget one if stock isn't enough for you otherwise.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1037083-will-it-work/#findComment-12330229
