There is a newegg sale going on...I can get some splitters for pennies but its molex to 2x 12v fan header and 2x 5v fan header.
What all in the PC world is powered off 5v 2pin headers?  Just these small fans Im looking at?  Anything in particular (their winter sale right now has a bunch of stuff at pennies to the dollar and free shipping if I spend $25 or more so I plan on buying at least that amount of somethings - or multiple things) so I can grab it up in the sale?  Ive got parts coming in for a custom loop, anything for loops that use 5v?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1036738-5v-fan-headers-why/
The only thing i can thinks is small enough is my fan in my raspberry pi 3 is 3.3 or 5 volts.
Not sure about you but I think my 7 year old CPU still rips
https://linustechtips.com/topic/1036738-5v-fan-headers-why/#findComment-12326654
Pretty much just fans. For example Noctua has a bunch of 5V fans, just search "5V" on their product page and you'll find just about every size of 5V fan out there from 40mm to 200mm.
https://noctua.at/en/products/fan
Other than that though most things for PCs have been designed for 12V, since that's the most common voltage in a PC nowadays.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1036738-5v-fan-headers-why/#findComment-12326655
all they're doing is tapping into the 5v and 12v rails of the molex connector. idk what fans are powered by 5v, but thats the power which the molex connector can provide
i like trains 🙂
https://linustechtips.com/topic/1036738-5v-fan-headers-why/#findComment-12326676
I wonder if their is a price delta, Ill have to investigate.  I need some 80mm SP fans for this project (2 80mm rads in a microtower)
Thanks!
https://linustechtips.com/topic/1036738-5v-fan-headers-why/#findComment-12326677
I've seen 2 pin fans before in some OEM builds, and on more specialized hardware. Generally they were < 120mm, but they're otherwise normal fans. As long as the specs line up with what you want/need, there's nothing wrong with em. You can search 2 pin PC fans on google/amazon and find relevant results
Edited by tarfeef101
lol 2 pin. i can read
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/1036738-5v-fan-headers-why/#findComment-12326723
1 minute ago, tarfeef101 said:
For 3-pin fans, their speed is controlled by voltage. So, you can use a 5V header to get a lower RPM that with a full 12V. This may or may not work depending on the fan (some may not operate at a voltage that low, some will), but is definitely useful in some cases.
Makes sense, like a voltage regulator.  I have some Arctic P12s that wouldn't work (because they need 60% power to start spinning up) - I see what you mean!
https://linustechtips.com/topic/1036738-5v-fan-headers-why/#findComment-12326731
