Hey, I am looking to build an emulation box pc. I have never built a PC but just want to have a crack at it for this.
want to keep it as cheap as possible but still make certain that it is capable of emulating all of the retro games as well as the newer stuff such as PS3 and Wii U.
any advice on where to start finding components and what I need would be great, I am very much a beginner at this.
thanks.
hoping to try and stay well under $1000 if possible
https://linustechtips.com/topic/1036155-emulation-build-help/
the graphic are not demanding on emulators,
ps3 (rpcs3) and wiiu (cemu) have developed quite well over past year.
wiiu needs a bit more optimization but already considered very playable.
ps3 is very cpu hungry. some demanding games are currently running at 20fps.
suggest a strong cpu for that(more than 9 thread heavily used).
ideally i9 9900k but ryzen 2700 is also very good.
https://linustechtips.com/topic/1036155-emulation-build-help/#findComment-12321504
PCPartPicker part list: https://pcpartpicker.com/list/g2YdQZ
Price breakdown by merchant: https://pcpartpicker.com/list/g2YdQZ/by_merchant/
CPU: AMD - Ryzen 7 1700X 3.4 GHz 8-Core Processor  ($191.90 @ OutletPC)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($19.99 @ B&H)
Motherboard: ASRock - X470 Master SLI/AC ATX AM4 Motherboard  ($133.98 @ Newegg)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($140.98 @ Newegg)
Storage: Western Digital - Black NVMe 500 GB M.2-2280 Solid State Drive  ($104.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($42.98 @ OutletPC)
Video Card: ASRock - Radeon RX 570 4 GB Phantom Gaming D Video Card  ($134.99 @ Newegg)
Case: Corsair - 200R ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: *EVGA - 750 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ B&H)
Total: $879.69
Generated by PCPartPicker 2019-02-21 00:41 EST-0500
https://linustechtips.com/topic/1036155-emulation-build-help/#findComment-12321621
