Streaming problem
Solved by Wubshu,
So my system had a "critical" windows update on 02/13/2019. I performed a system restore to before that point and now seems to be working like before. I did a small test with the ?bandwidthtest=true method on Twitch and so far so good. I will have to test a full stream tomorrow to verify that it is working like it should. I'm going to hold off on hitting the problem solved checkmark until I am sure it is back to normal. Anybody else encounter this kind of thing with windows updates?
