Can i clean heatsink with water?
Shyxap
I have Noctua NH-U9S and i was wondering if i could just to spray it with water to clean it and ease my work that way and save my tooth brush from all that dust.
i worry about mainly corrosion as i don't know the metals used in this cooler
Aluminum and copper should not corrode with water as long as it is allowed to dry thoroughly.
AMD 2600x | 16gb Trident Z RGB | Asus ROG Strix B450F | Samsung 860 Evo 1tb | Phanteks P400 | Asus GTX 1060 DUAL
That is a first for me to hear.  Watering it down lol.  Its gonna cause corrosion you don't want that.  Just clean it with a powerful blower.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
It wont corrode. Der8auer said he even uses dishwashers without detergent.
Water is great for washing the heatsink. Just dry it before reinstalling.
Yes :D Thats how I cleaned my original U9B before installing U14S in its place. Washed it under running water, without soap, and let it dry for day or two. Cleaned fan by wiping blades with soft paper towels. That thing is still operational.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Compressed air, and like the others have said it won't corrode as long as you let it dry.
just.. ya know sometimes it needs a good wipe down and spray.
If my answer got you to your solution make sure to 'Mark Resolved!
( / . _ . / )
When I clean my heat sink like for my Evo 212,I first use compressed air to clean out any dust and then I wash it in warm water, And if it’s the summer I’ll put it out in the sun and let it dry completely if it’s winter I would use a hair dryer.
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
