Hey guys I recently built my PC.
This is my build:
https://ca.pcpartpicker.com/list/jrm43b
So the corsair ram I bought was auto set to 2133 mhz, even though it is 3000 mhz. So i used the DCOP profile available to set it to 3000 mhz. I have linked the pictures, which show the DCOP settings (note I have saved these setting and restarted my pc multiple times to ensure they were set). However as you can see from the second image, even though the DCOP has changed frequency to 3000 mhz and voltage to 1.35V, the settings on the right of the second image still shows the voltage as 1.2 V rather than the new 1.35 V (although the frequency has changed to 3000 mhz). Furthermore, as seen in the third image, when i went into other settings, DIMM is still shwoing frequency at 2133 mhz. So im just wondering, am I doing something wrong and has the RAM frequency truly changed, because I dont want to mess up anything at the wrong voltage.
https://linustechtips.com/topic/1035865-need-help-with-ram-docp/
This is my build:
Try using the X.M.P profile that might yield a good result and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Bios 0207 but I only find 0504, 0602, 1003, 1103 and 1201 on the page of the board. Strange. Is that the latest bios you could have?
https://www.asus.com/us/Motherboards/ROG-STRIX-B450-F-GAMING/HelpDesk_Download/
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Hey I just noticed that too, would updating it to 1201 work? Also to update it would I just need to download it from the website?
PS: sorry for the double comment, new to the website, so I wasnt sure if you get notified without a quote
Bios flash instructions are usually found in the manual. https://www.asus.com/us/Motherboards/ROG-STRIX-B450-F-GAMING/HelpDesk_Manual/
DOCP is Asuses name for XMP that they use on AMD systems.
Oh I see didn't know that.  How about if you manually go and set it to 3000Mhz and not use DOCP .... ?
Let's first see what the confusion with the bios versions turns out to be.
The latest bios should include AGESA 1.0.0.6 which should solve some memory related issues.
Hey it looks like BIOS 0207 is the version it comes with.
https://www.asus.com/au/Motherboards/ROG-STRIX-B450-F-GAMING/HelpDesk_CPU/  [mine is ryzen 5 2600]
So should i go ahead and try to update it or stick to the bios it came with and try to find another solution?
Update the bios. If 0207 is what the board comes with it has to be some old version.
Agesa 1.0.0.6 improves memory compatibility a lot.
Hey just wanted to give an update. I did end up updating the bios to the new 1201 version and everything is running perfectly now, the frequency and voltages. Thanks alot!
  • 1 year later...
