MOBO - Gigabyte H370 AORUS GAMING 3 WIFI
CPU - i5 8600
RAM - Ripjaws V 16GB (8GB x 2) 2666MHz DDR4
GPU - AORUS Radeon RX580 8G
SSD - WD Blue 3D Nand 500GB M.2
PSU - Corsair TX650M 650 Watt 80 Plus Gold
CASE - CM MasterCase H500
MONITOR - LG 24UD58 FreeSync
KB - Logitech G413 Carbon
MS - Logitech G402 Hyperion Fury
PAD - Logitech G440
1. Budget & Location: Around 100K INR for hardware, from Bangalore (India).
2. Aim
- Campaign gaming (RPG, FPS, Racing, ex: Witcher, NFS series, MassEffect series, Skyrim, Dragon Age, COD, GTA) and occasional CSGO, EVE Online.
- Work (Virtual Machines, Android/Unity Development as personal hobbies).
- Movies, TV series.
3. Monitors: Single monitor.
4. Peripherals: Included as part of build.
5. Why are you upgrading?This will be my first PC configuration.
Preference will be for the intel build, but AMD suggestions are welcome. Requesting explanation for alternatives.
No plans for overclocking. Wont be bothered if it cannot run everything at extreme setting or highest FPS.
https://linustechtips.com/topic/1035422-build-review/
That SSD is only a Sata 3 drive, not NVMe so it will only perform the same as a standard 2.5" ssd. Rest looks fine to me.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1035422-build-review/#findComment-12314697
Yes, I went for normal SSD instead of NVMe since I'm getting double the storage for same price and I wont be having tasks that can fully take advantage of the NVMe speed.
Please correct me if I'm mistaken.
https://linustechtips.com/topic/1035422-build-review/#findComment-12318095
