13 hours ago, Antonios said:
I have an AB350M Pro4 with a M2 SSD 256 GB and I want to add one more M2 SSD 512 GB. Is that possible? Are there available slots on the motherboard or I have to buy a 2.5΄΄?
As u want to add 512 gb more buying 2.5 inch is the only way as ur mb has only 1 m.2 slot
My Rig
HP Omen 16 | 13th Gen Intel(R) Core(TM) i7-13700HX | 16 GB DDR5 RAM | NVIDIA Geforce RTX 4060 8 GB | 512GB PCIe Gen4 NVMe TLC M.2 SSD |
16.1-inch (40.9 cm) 1920 x 1080 165Hz | RGB Backlit Keyboard |
https://linustechtips.com/topic/1035126-second-hard-drive/#findComment-12312318
On 2/20/2019 at 8:10 AM, Antonios said:
Yup its a good SSD and iam using it for my pc. You can also consider Samsung SSDs but they r little expensive compared to WD.
My Rig
https://linustechtips.com/topic/1035126-second-hard-drive/#findComment-12331020
