My build:
intel 4790K
MSI gaming 5 z97 motherboard
gigabyte windforce 970 nvidia gpu
RM600 psu (600w)
h100i liquid coller
ddr3 16GB ram
running windows 10
My pc switches off at random, even when there's not much load.
Here, by switches off, I do not mean like a total shutdown.
The led on cpu cooler is on, led on the motherboard is on, and all the fans are on except for the one facing rear (for which the power cable is connected on the motherboard, I've connected other fans directly to psu).
The keyboardmouse and monitor are in off condition.
Recently I am not able to even switch on my pc.
when i try to switch on, the above-explained scenario occurs.
But when I toggle the power switch behind the psu a couple of times, it starts by luck.
I initially thought that there was a voltage problem and changed my ups but the problem persists.
There seems to be no temperature issue.
I also tried removing GPU all-together but still not fixed.
(note: I did not overclock any component)
Please guide me towards a fix
regards
(note: please reply with added detail. Noob here).
https://linustechtips.com/topic/1035107-power-off-at-random/
if fiddling with the PSU fixes it, I'd be inclined to believe that's the issue.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1035107-power-off-at-random/#findComment-12312151
