I think you'll be out of luck finding anything decent in that price range. Headphones with NC from reputable brands start at about ~180€ for the features you're listing.
Maybe try refurbished/used headphones?
75% of what I say is sarcastic
So is the rest probably
https://linustechtips.com/topic/1035056-headset-for-work/#findComment-12311671
it dont need Active NC, it just have to reduce the sound a little bit
https://linustechtips.com/topic/1035056-headset-for-work/#findComment-12311736
https://linustechtips.com/topic/1035056-headset-for-work/#findComment-12311750
