Honestly, whichever one you like the looks of better. They both have adequate airflow so IMO it doesn't matter which one you go with.
If you really want to get technical then the master q is all mesh while the p6 has that front plastic decorative piece that I suppose could hurt the airflow a small percentage. Again, not enough to where you have to worry about it.
~Air Cooling Advocate~
https://linustechtips.com/topic/1034890-better-airflow/#findComment-12310169
1 hour ago, bebejapes said:
what air cooler will you be using.
The case hase issue if its too close to the wall or in a cupboard like structure
 Will be 2 inches away from wall and the side of the cables will face the wall (basically a corner)
https://linustechtips.com/topic/1034890-better-airflow/#findComment-12310370
