White define r4 side panel?
Solved by roid,
have you already gotten a define r4 without a window? If you havent then heres one on newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16811352025.
edit: define white r3 side window:http://www.fractal-design.com/home/product/accessories/define-r3-white-window-side-panel
Specifications- Product dimensions: (W x H) 480 x 427mm
define r4 side window (black) should be same dimension as white though):http://www.fractal-design.com/home/product/accessories/define-r4-black-window-side-panel
Specifications
- Product dimensions: (W x H) 480 x 439mm
*The R3 window panel compared to the r4 window panel is the same width however its 12mm shorter then the r4 panel, which will cause a big gap.
