I just built my first computer and am looking into overclocking, but have no idea how. My system is:
i7-8700k cpu
Noctua NH-D9L cpu cooler
ASrock Z390 Phantom Gaming SLI/ac motherboard
G.Skill Value DDR4-2666 memory (16gb)
TEAM T-force Delta 1TB SSD storage
MSI RTX 2080 VENTUS GPU (coming in a few days)
Rosewill 650w 80+ gold full modular psu
Anything is appreciated, thanks!
https://linustechtips.com/topic/1034689-overclocking-help/
What do you want to overclock (CPU, GPU, DRAM)?
Here's a very short GPU overclocking guide:
- Download MSI Afterburner and Unigine Valley Benchmark
- Increase the core clock by a bit at a time (maybe 25MHz at a time) and same goes for memory.
- Then stress test your GPU (run Unigine Valley Benchmark) for some time.
- If the application doesn't crash, then your overclock is stable but if Unigine Valley Benchmark crashes, then your overclock isn't stable.
- If your app crashes, you have two options: either add more voltage or decrease the core/memory clock.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1034689-overclocking-help/#findComment-12308674
Just now, Poseidon123789 said:
Thanks for the help. I definitely want to overclock my GPU and probably memory, do you think its worth overclocking the CPU for gaming?
Nope. GPU overclocking will help a lot more for gaming than CPU overclocking will.
https://linustechtips.com/topic/1034689-overclocking-help/#findComment-12308698
