Phone is LG G2, firstly I never had this problem ever before since now. I use my otg cable to power my headphone amp that I have that works with usb power input and it's usb end is not 100% as good as the first day so when I touch it, it sometimes cuts the power flowing. Sometimes you know these disconnections and reconnections happen in a row because the way I hold the cable, so there's that. But like I said I've been using my phone like this for a long time without a problem. Now when I plug the otg it works fine for a while without getting hot what so ever (while checking temperature sensors from CPU-Z). But when the disconnect thing happens it says high temperature and boom, phone goes off. Any help, any lil knowledge will do, thanks :)
https://linustechtips.com/topic/1034334-high-temperature-warning-when-plugged-otg/
pulling too much power?
Desktop benching:
