Can someone help?
Solved by WebPlayz,
3 minutes ago, SGBudgetGamer said:I'm not sure what's out there for free it's my first time, I want to check my cpu and gpu performance and also compare I'm also learning overclocking my cpu on youtube as well.
https://www.maxon.net/en/products/cinebench/ - Cinebench for CPU
https://www.aida64.com/downloads - Aida64 Demo for CPU
https://benchmark.unigine.com/ - You can pick what ones you want for testing your GPU
Hope this helps
