PSU: corsair hx850i
gpu: asus strix 1080ti (custom watercooled)
cpu: ryzen 1700 (oc to 3.7ghz)
mobo: asus strix b350
I have had shutdown problems where my monitor would shut off as normal, but my rgb (ram, gpu, mobo) would stay on along with my pump and all case fans (pc was still on).  The only way i could power it down was to shut off my psu.  I have updated the bios and have all latest drivers and widows updates.  5 days ago I reseated all of my cables (which are stock) and this seem to fix it temperately.  Now 5 days later the same problem is present.  All of my components are brand new and have worked great for the past 1.5 years.  My pc is fairly dusty as I have not cleaned it in a while.  Does anyone know how to fix this?
Thanks.
https://linustechtips.com/topic/1034078-shutdown-problems/
20 minutes ago, White_Mamba77 said:
PSU: corsair hx850i
Thanks.
This is a WInblows problem your hardware and setup is just fine and dandy.  You can blame Uncle Billy for this.  Also your not guaranteed a fix if you format and clean install and what not.  Perhaps the April update will tackle the issue, but I wouldn't bet on it.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1034078-shutdown-problems/#findComment-12304255
