I am looking to build my first pc. I have done quite a bit of research in the last month or so but I have quite limited experience. My budget is around $1500-$1700 (AUD) and it would be used primarily for gaming, school work, and general web browsing.
The part list is:
• AMD Ryzen 5 2600
• EITHER a GTX 2070 or RTX 2060 (which one would you recommend)
• MSI B450 Gaming Pro Carbon AC motherboard
• 16 GB (2 x 8 GB) of DDR4-3000 RAM
• Silverstone 600 W, 80+ Bronze PSU
• Seagate Barracuda 2 TB HDD
• Either a 250 GB or 500 GB SSD (SSD will hold windows 10, and my most played games, what size would you recommend?)
• Thermaltake Versa J25 Case
What do you think of my build? Should I get the GTX 1070 or RTX 2060? 250 GB or 500 GB SSD? Any other feedback or help on the build?
Any and all help is appreciated,
Thanks
https://linustechtips.com/topic/1033868-first-build-help/
you're spending stupid amounts of money on the ram, you can get a similar kit for less than half that price.
https://linustechtips.com/topic/1033868-first-build-help/#findComment-12302101
I just realised the price went up since I added it to the list, it was on sale for $175. Is the G. Skill Ripjaw V a good choice?
https://linustechtips.com/topic/1033868-first-build-help/#findComment-12302105
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($235.84 @ Amazon Australia)
Motherboard: MSI - B450 Gaming Plus ATX AM4 Motherboard  ($134.00 @ PC Byte) get a pci-e wifi adapter if you need wifi.
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3000 Memory  ($175.00 @ Umart)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive  ($99.00 @ Austin Computers)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($85.00 @ PC Byte)
Video Card: EVGA - GeForce RTX 2070 8 GB Black Video Card  ($769.00 @ Umart)
Case: Thermaltake - Versa J25 Tempered Glass RGB Edition ATX Mid Tower Case  ($98.00 @ Shopping Express)
Power Supply: Antec - Earthwatts Gold Pro 550 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($105.00 @ IJK)
Total: $1700.84
Generated by PCPartPicker 2019-02-15 23:26 AEDT+1100
https://linustechtips.com/topic/1033868-first-build-help/#findComment-12302106
yea it's fine.
https://linustechtips.com/topic/1033868-first-build-help/#findComment-12302112
Total: $1700.84
I just saw your reply, I’ll give this a look.
https://linustechtips.com/topic/1033868-first-build-help/#findComment-12302125
Total: $1700.84
Is an RTX 2070 overkill for 1080p gaming on a 144hz monitor?
https://linustechtips.com/topic/1033868-first-build-help/#findComment-12302135
it'll last longer before needing an upgrade, you can keep it unless you need the money for something else.
https://linustechtips.com/topic/1033868-first-build-help/#findComment-12302357
