Hello!
What do you think of my almost finished inverted case?
Need to replace all fans to Corsair ML, have only 2 at the moment, on the cpu cooler push/pull.
And replace the red sata cables to black.
What do you think?
Any other change?
All criticism are welcome.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1033632-inverted-modified-case/
my OCD is hating this one...
Systems:
Main Gaming:                                                        Windows XP:
Ryzen 5 2600                                                               Intel Pentium 3
Asus RX 580 OC                                                     1GB DDR2
Patriot Viper DDR4 8GB                                         Asus Motherboard
Asus ROG B450-I                                                   Dell 300W
Corsair CX 450                                                       ATI Rage 128 Fury Pro
FreeNAS Server:                                                   Windows 98/95 duel boot:
I5 3400k        Pentium Pro
Patriot DDR3 8GB                                                  HP Vectra motherboard
Gigabyte Ultra Durable                                           500MB RAM
Rosewill Glacier 600W                                           Soundblaster 16
        Matrox Mystique
Random PC:
AMD Phenom x4 850                                          Key:
Kukete A78                                                          Motherboard
Kingston 4GB DDR3                                            Memory
Dell 500W                                                            Power Supply
        Graphics Card
Other Gaming:                                                    Sound Card
Ryzen 5 2600                                                       Processor
Asus ROG Strix B350-F Gaming
MSI 1050 OC
Hyper-X 16GB DDR4
EVGA 750 B2
https://linustechtips.com/topic/1033632-inverted-modified-case/#findComment-12299915
This is one of those moments where "just because you can doesn't mean you should". What is the point of this, and i'm not saying that to be a dick, i'm actually asking what was the point/benefit of this build. Actually after looking closer, did you just flip your entire case upside and take a picture of it? Because if you did than I commend the troll job
https://linustechtips.com/topic/1033632-inverted-modified-case/#findComment-12300870
It has no point, if it had a point then
1. the CPU heat-sink should be reversed
2. Power supply sticker removed and applied "upside down"
3. GPU flipped (don't know possibility on that one)
Might as well:
Systems:
        Matrox Mystique
Random PC:
        Graphics Card
MSI 1050 OC
Hyper-X 16GB DDR4
EVGA 750 B2
https://linustechtips.com/topic/1033632-inverted-modified-case/#findComment-12300949
I do not troll, the case is inverted.
https://linustechtips.com/topic/1033632-inverted-modified-case/#findComment-12301297
First of all and the air flow, the air flow is fantastic in this case, 2 front intake, 2 top intake, 1 bottom intake and the back exhaust, all the gpu's that i had in there, never went more than 62c~63c and the cpu max 72 with this 40$ air cooler (well i changed the fans to Corsair ML), but even with older cpu's
2nd i have it almost 10 years, put a lot of work in it and i kinda fall in love with it, it is compact not to big not to small
https://linustechtips.com/topic/1033632-inverted-modified-case/#findComment-12301313
  • 3 weeks later...
