DT770Pro 30ohm + HyperX USB Soundcard
SnowGhost1212
So I've recently bought the 30ohm DT770Pro's because I didn't have the budget or the will to invest in a full Amp/DAC system. Upon listening to some songs I notice a small white noise / hum during breaks in songs. I thought perhaps an amp would help and I have the USB Soundcard that comes with the Cloud II's so I thought I'd pair them. This didn't fix the hum so I think it might just be caused by the source of the audio (Spotify) but it does drive the headphones louder. I understand this isn't a high quality soundcard so I was wondering if I was degrading my audio quality at all using it or its fine to use them together?
Cheers,
S
