7 minutes ago, Skywarp said:
Is the 8600k a good upgrade or should I upgrade to something else?
You would need a new motherboard as the 8600k is not compatible with the same motherboards your 7600k uses.
I wouldn't bother upgrading from a 7600k to 8600k though. While there would be some performance improvement, I don't think it would be worth the cost.
Do you currently have a z170/z270 motherboard? If so, try overclocking your 7600k to improve performance.
https://linustechtips.com/topic/1033279-need-a-lil-help/#findComment-12296469
I currently have an Asus ATX DDR Intel LGA 1151 SATA III (6Gbit/s) Gaming/Aura Motherboard (B150 PRO)
https://linustechtips.com/topic/1033279-need-a-lil-help/#findComment-12296489
If it's a b150 motherboard you won't be able to overclock the CPU.
Maybe someone with more experience with the oculus can help you out.
https://linustechtips.com/topic/1033279-need-a-lil-help/#findComment-12296518
