Hi gang!
Im aware this is primarily a hardware community (or at the very least, not an iPhone/apple one!) but I’m not really a member of any others and it felt silly to sign up for one just to make this post, so, here goes.
My friend is having an issue with her iPhone which is stopping her from disableing automatic timezone detection, the option is just greyed out, whereas for mine, it’s not locked and I can switch between having it locked or unlocked.
Anyone know why this is or have a solution for this?
Thanks guys!
https://linustechtips.com/topic/1032791-ios-help/
Try to back-up with iTunes and do a wipe and restore, if the problem persists, reset to factory and don't restore anything and check if you can modify that setting then.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/1032791-ios-help/#findComment-12291793
