Apex legends sound bug
Go to solution Solved by Crunken,
3 minutes ago, theoo1 said:
have you found a fix? I have the exact same problem
upgraded my graphics card today so uninstalled all my drivers with DDU, it's fixed the problem for now, so try reinstalling drivers. Otherwise a lot of people have fixed it by changing from stereo to 7.1 in sound options or the other way around
21 minutes ago, Crunken said:
When i play apex i hear enemy gunshots like 30 seconds after they shoot? nothing else with the sound is bugged and works fine in every other app/game. Anyone know a fix? (got headset on stereo in windows settings already)
Please give us more info about your computer.  Please fill out the signature if you can, so we can help you better.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1032446-apex-legends-sound-bug/#findComment-12288553
Yeah gotta do that, just haven't had the time. But this is a ingame bug it works fine in other games so i have a feeling it's more a software issue than hardware
Either way my specs are
CPU: i7 4770
GPU: GTX 970 (gonna upgrade to a 2060 in 2 weeks ish)
MOBO: MSI H97 GAMING 3
RAM: Corsair Vengeance DDR3 1600MHz 8GB
PSU: Cooler Master Silent Pro Gold 550W PSU
Headset: HyperX Cloud II (straight into mobo)
https://linustechtips.com/topic/1032446-apex-legends-sound-bug/#findComment-12288568
CPU: i7 4770
That 2060 6GB will do excellent in 1080p gaming with all nvpanel settings set to on and in game to ultra.. You should get 80 to 120fps easy.  Have you tried pruning the drivers and installing them fresh or install a different version like one version older and what not.
https://linustechtips.com/topic/1032446-apex-legends-sound-bug/#findComment-12288575
CPU: i7 4770
https://linustechtips.com/topic/1032446-apex-legends-sound-bug/#findComment-12296277
https://linustechtips.com/topic/1032446-apex-legends-sound-bug/#findComment-12296299
