Hey!
I have an issue resolutions while streaming..
So i what i want to stream in is 720p.
My video settings is:
Base (canvas) resolution: 1080p
Output (scaled) resolution 720p
Downscale filter Lanczos
Advanced output stream setting
Encoder - NVEC
*checked* - Enforce streaming service encoder settings
*checked* - rescale output
- Output resolution 720p
Now, everytime i broadcast on twitch i get 1080p streams, why? Shouldnt it be 720p?
Also, after every broadcast my advanced settings are reset.
If i inspect my settings DURING A LIVE STREAM my video setting for output jumps back to 1080p and becomes grayed out, despite that i was 720p before stream started.
TL;DR - Stream resets my output resolution, cant stream 720p, no matter what i change it becomes 1080p
https://linustechtips.com/topic/1032337-streamlabs-obs-issue/
Streamlabs OBS has tons of problem and issues with the past few patches and updates. I am in some large stream communities and this is a prevalent problem. Just switch and use regular OBS and all your problems solved.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1032337-streamlabs-obs-issue/#findComment-12287565
